Galen wrote:
Thanks Bob, I did a quick measurement off of the picture of the ISM PL1.1 it only looks like it measures 175mm to the nose from the back of the saddlerail.
This is typical of the split or stubnose saddles, I'm looking for a longer nose, probably going to be a more traditional shape.
if you're rotating your hips forward properly, you're effectively lengthening your back by inches, not millimeters.
For reference, I've ridden my Fizik Mistica saddle as much as -10cm to tip of saddle behind the BB, with a pad reach way longer than anyone else on this forum most likely. This same situation can be achieved with most split nosed saddles, like Dash, ISM narrow and long and short families, etc. Find the one you like and go from there.
If you're doing short course or TT, my advice might be different. I could see a use case for using a regular long nosed saddle in UCI TT applications.
Eric
Eric Reid
AeroFit |
Instagram Portfolio Aerodynamic Retul Bike Fitting
