A while back, I got a bike fit in Dallas and subsequently picked up a 54cm Cervelo P2. Over the weekend I finally had time to try an adjust the bike as best I could. There should be a video and fit sheet in the OneDrive link.
- The aerobars have been replaced from the stock to 3T Brezza II bars.
- The saddle is a Sitero
1. The reach is currently 20mm short of the fit coordinates. If I'm to adjust that, is there a reason to just get a new stem versus spending a bit more and getting the Tririg Ergo pads and use those to gain some reach? The extension are short enough as is. Losing 20mm by just more pads forward might be tricky.
2a. My saddle set-back should be -14mm. Right now, I'm well behind that. It doesn't appear I can get the saddle that far forward. Am I measure something wrong or is this a case where only certain saddles can get me that far forward? On a Sitero, should I be measuring to the nose or to the front of the texture marks?
2b. I can find a comfortable spot on this saddle, however, it tend to find myself quick coming forward from that position. I don't know if that's me trying to get back to the position I should be in or the seat being too sloped.
3. Any other suggestions?
