TheStroBro wrote:
So...since you work there, perhaps you can talk to the right person. The ones without BCAAs, discontinue or change formula. Standardize the amount of BCAA, Salts, and Caffeine in every GU. I suspect you could go Caffeinated and Not-Caffeinated. But, me, as the consumer gets annoyed when I'm trying to build out my race nutrition and the formula of Salts and BCAA is not standardized. THANKS.
I guess it depends on how deficient you are. If you're a vegetarian/Vegan/non-Red Meat person then a lot more often.
If you do eat Red Meat, red meat is loaded with BCAAs. So then you could just do intra workout. Depending on how hard I workout I may have a scoop afterwards but I always have a single serving when lifting.
I'm just the Colorado rep, but I can pass along your comments to the right team.
I think the rational is to provide different options for different folks with different needs. Not being a scientist either, I wonder if there are some combinations of ingredients that cant go together? Hence the need for Electrolyte caps to be different from the Roctane BCAA caps.
But thanks for the input. See ya out on the trails.
Jeff
Jeff Abbott - @run1fast
jabbott@headsweats.com
Headsweats - Custom Team singlets $8 / Cycling Jerseys $25
Abbott Event Solutions - Brand Rep and Event Manager
