Tom_hampton wrote:
No one was making suggestions to you. The OP asked for suggestions, and a couple of comments were made about his seat perhaps being 5mm too high (or perhaps not).
Jim suggested that Fuller could go to shorter cranks (without moving the saddle) in order to effectively shorten the pedal stroke, with the added benefit of slightly opening up the hip angle over the top. You seemed to misunderstand the "don't move the saddle" bit, thinking that shorter cranks would require raising the seat+cockpit and potentially increasing his Frontal area---a point that is not true, which I clarified.
You mentioned that you have some knee problems, as justification for why you have such a "very high seat" (fuller didn't mention any such issues...so, not really relevant to his fit). I pointed out that shorter cranks might be an alternate solution for your knee problem, as something to consider. But, the reality is without a much better understanding of your knee "pain" and exactly where it occurs in your pedal stroke and why...maybe they would help, maybe not. That's why I simply said, "something to consider" and stopped short of making an outright recommendation.
Of course it all comes down to comfort. That's the whole point of a bike fit. It doesn't matter how aero someone is if they aren't comfortable. That's doubly true for crank length...as they have almost zero impact on aero directly. Only indirectly, insofar as they may make a more aero position more comfortable.
Its been noted many times by most of the best professional fitters around here that there really doesn't seem to be a downside to shorter cranks---at least when it comes to actually available crank lengths. Personally, I'm on 150mm cranks (the shortest I could buy)...I jumped straight from 175 to 150. Once the fit was properly adjusted to compensate, my effective power output was unaffected. I did FTP tests the week before and after to be able to ensure that very fact. But, overall my position was substantially more aero. My CdA is about the same as Fuller.
If you are extremely toe-down (plantar flexed) at the bottom of the stroke, you may be losing power through your fit...shorter cranks MIGHT enable you to have a more (or equally) comfortable AND more powerful pedal stroke without necessitating any aero change to your cockpit or riding position. Further, that type of pedaling mechanics CAN create its own issues. But if you're happy with what your doing and you don't want to consider it, its no skin off my nose. I was only trying to make a potentially helpful suggestion.
All the original comments were directed at the OP, anyway.
Well...it went off topic. But, basically Viewed it from my own experience, since I Can’t feel what anyone else is feeling when on the bike. And I do have Odd dimensions to my body. As for shorter than 165 cranks, I did try 155 once and felt the sensation of being in a kids tri-cycle. I do realise the theoretical benefits of a shorter cranks, it’s just not everyone. My point is, wether you like 155 or 165 cranks is probably a matter of individual preferences.
Aside from that, it’s worth noring that when changing crank length, you’re effectively changing the gearing as well.
