RChung wrote:
Thanks. OK, a couple of little things: that max power is articfactual there are 4 records of exactly 1 second length each that are > 800 watts -- they occur for only a second, and the power immediately before each was 0, and the speed in the second after each high power second did not appreciably change.
All that said, those 4 records are *not* the cause for the unusually high NP.
I can't replicate the Bolt's estimate of NP for the entire ride, but I still get a pretty high value: 203 NP rather than the Bolt's 212. That's for just over 4 hours.
More pointedly, what was happening in your ride from about 2h20m to about 2h40m? They definitely look like intervals to me. How hard were those 20 minutes in a subjective sense?
2:20 was the start of a long, fast downhill, followed by a relatively flat to slightly uphill section, followed by a downhill to a stop at a highway (where that 1400W spike occurred on starting across) around 2:28. 2:28 to 2:31 was an uphill, followed by the steepest hill on the entire ride ("Hooper") from 2:31 to 2:35. 2:35 to 2:36 was a downhill, followed by another very steep uphill from 2:36 to 2:39 ("Belvidere"). So, easy, relatively easy, easy, very/very/very hard, easy, very/very hard. From 2:31 to 2:35 was a climb (Hooper and a bit thereafter that also climbed) punctuated by very brief flat/downhill bits, hence the zero power you see as "between intervals". After 2:40 is a flat bit with a great view of the NYC skyline (also with zero power for 10-20 seconds). The graphs I see in Strava match the terrain perfectly, and would look like "intervals", for sure.
The Hooper Strava segment was 1:13 at 385W; I debated whether to attempt it, as I know it is very steep (12% average, max 22% according to Strava) although only ~300yds long. Belvidere was 2:07 at 294W. I was almost toast on Belvidere after nearly three hours of climbing. The subsequent climb a few minutes later (2:50 @ 252W) was taken at about the minimum effort needed to get up it (irrelevant comment: the top of that climb is the highest point on the Eastern Seaboard (Twin Lights)).
Curious where are those four artifacts you mention, so I can see what was happening at that point.
"Go yell at an M&M"
