Am I to far forward?
I know this position is fast as 230 watts gets me 24.5-25mph over 40k. Is it to far forward though. Could I stay as aero and move back?
https://ibb.co/mRZZbo
Re: Am I to far forward? [Insilvis] [ In reply to ]
Is there a problem you are trying to solve?
Re: Am I to far forward? [Tom_hampton] [ In reply to ]
Not really. I have had others comment that I’m VERY far forward on the bike and that moving back may give more power. I do take a knock to my power but I think if I train in the position more it will come back. Just trying to make sure I’m not doing something really wrong.
The curve or arch in your spine makes looking up the road and keeping your head low difficult. This is maybe why you are looking down. You might try coming back and down maybe 5 mm and see if that flattens your back. You might also tilt the nose of the seat down a couple degrees and see how that feels.
My gut instinct is that your saddle isn't quite right and your hips are rotated up for comfort. An improvement in comfort from tipping the saddle down would suggest a different saddle is needed, or maybe just minor adjustment of you are lucky.
Are you too far forward compared to what? Sure you have the forward setback seat post, but it looks like you have a couple of inches you could still slam your seat forward even further if you wanted to. If you are aero and fast and it is comfortable and you can push good watts and the bike handles well then I would say who cares what other people say.
Save: $20 on Air Relax Recovery Boots| $100 on Normatec| 15% on The Most Absorbable Magnesium | Best $50 Indoor Cycling Desk
Blogs: 2018 Normatec Pulse vs 2015-2017 Normatec Pulse | QUICK Air Relax Travel Case Review | Q1 2018 Blood Test Results | Why Latex Bikes Tubes | Vittoria Corsa Speed Aero Data | 10 Reasons To Consider HED JET+
How is the bike handling?
I couldn't ride like that on the open road.
Would feel like I am riding a unicycle and that I am gonna pitch over the bars if I just touch the brakes.
Hence on a technical course, that position would cost me at least 1 mph.
YMMV..
Personally I think it looks like you could go back but I think your problem may be with your seat as it looks like you need to rotate your pelvis more and may help you moving your seat back. I find a bike fit starts with the correct seat.
I don't see anything obviously wrong with your fit. Looks very similar to mine. I wouldn't change a thing.
get comfortable being uncomfortable
Re: Am I to far forward? [stevej] [ In reply to ]
+1 i dont see you being too far forward at all. My saddle setback is 2cm. And its an Adamo. I dont know if thats considered forward, but i find it comfy. If your the same why change?
Camera angle isn't perfect, but subtracting the 3 deg bike tilt gives approx. effective seat angle of 81 deg. So, not too forward. Note this is only an isolated comment on seat angle and not position as a whole, which looks to be solid (i.e., without pic/video at top of pedal stroke I can't comment on hip angle and/or crank length and how that may impact seat angle).
Your position is better than probabaly 90+ percent of ST and 99 percent everyone else. I wouldn’t worry about it.
Generally I’m as far forward as the saddle can handle. Unless like with p5 right now, I can’t get as much drop as I want so I’m set back a bit more than normal to open my elbow angle. Really should of bought a 51. Oh well.
De Soto Sport Athlete
Formerly Draketriathlon
Look at his stomach. It is pulled in. This suggests that the stomach muscles are flexed in an attempt to roll the hips up/back to relieve pressure on his soft tissue. The problem would be that it restricts the depth that the diaphragm can push the organs down. This limits lung capacity. I would rather see what appears to be a beer gut, that could interfere with his thighs at the top of the pedal stroke, than that super narrow/tight looking abs.
Re: Am I to far forward? [grumpier.mike] [ In reply to ]
I agree that it looks like my core is really working and in this photo in this exact moment it may have been. Hard to say what I was doing in that moment. I road three hours today with an hour of it a LT and it felt fine. Handling feels fine. There have been no red flags or alarms. If i focus on getting long on the bike then I think by back has less of an arch. I can try to get more photos.Other then the power loss in aero there has been no negatives. Just want to make sure I wasn't obviously doing something wrong.
As I quoted earlier do you not think this is due to the wrong saddle. I think with the right saddle and pressure relief he may rotate and the may want to push the seat back when seated correctly.
