Sbsteve wrote:
As I get older I can tell my body just isn't recovering like it use to.
Is anyone using the Air Relax leg recovery system? Can you give me the pros/cons to this less expensive system? Does it seem to help?
Thanks in advance.
I have used a variety of systems out there and have worked with all the brands in some capacity at various points. I compared both
Air Relax against Normatec, and
Speed Hound here. When I first took a look at Air Relax it was ~about $350 and Normatec was about $1800. That gap has narrowed significantly.
Amazon just had Normatec on sale for Prime day at $899. I suspect we will probably see that again on Black Friday. I was kind of surprised when Normatec moved the price from $1295 => $999 earlier this year as I really thought it would be temporary but the price has stuck. Air Relax and Speed Hound will likely have some sort of Black Friday promotion as well.
The Pros of Cheaper System - More affordable
- Different modes of compression
- In the case of Speed Hound, very slick UI
- In the case of Speed Hound, there shorts are better than Normatec. Air Relax shorts feedback is they are generally too big and not enough compression. I do prefer the style more than Normatec
- Higher pressure if that is your thing
- Speed Hound owner is a triathlete and ST lurker
- Both Air Relax and Speed Hound are small-biz owners
Cons - Larger, heavier
- May not have same name brand recognition
- No Bluetooth. Normatec Bluetooth may be a feature some use although I don't use it personally.
- Some people get annoyed by 15-minute session limit on Air Relax. All you have to do is just hit the start button again, really really easy, but just something I hear from time to time.
As for the use. Yes, compression boots are great and are a no-brainer IMHO. Very relaxing. I personally found when I was training hard that I could personally recover better while using them. Even from a young-age, like first cross-country meet in high-school I was more stiff and sore than my peers. It maybe my run style that caused that. Regardless I definitely find that I am less sore after using them and can do more consecutive days. Scientifically they are proven to increase range of motion. I am sure with properly designed studies they could be proven to do more things. There is a reason why compression boots are so ubiquitous amongst all professional athletes, not just triathletes.
One of my own favorite uses of compression boots that is rarely talked about is the benefit to using them pre-workout in big blocks of training. Really gets everything warm, primed and ready for action.
As far as which one I recommend. I generally steer affordability seekers to
Speed Hound. Great customer service, 45-day love them guarantee. About $100 more than
Air Relax.
Save: $50 on Speed Hound Recovery Boots |
$20 on Air Relax|
$100 on Normatec|
15% on Most Absorbable Magnesium Blogs: Best CHEAP Zwift / Bike Trainer Desk |
Theragun G3 vs $140 Bivi Percussive Massager |
Normatec Pulse 2.0 vs Normatec Pulse |
Speed Hound vs Normatec |
Air Relax vs Normatec | Q1 2018 Blood Test Results | |
Why HED JET+ Is The BEST value wheelset
