I feel like it's always a crapshoot. Ultimately, if you are looking to place as high as possible, you would compare where you fall on the distribution of both W/kg and W/Cda and then pick where you are best
relative to your competitors. So there isn't a fixed cutoff per se, rather, you would have to look at where you rank in each race.
There is also the heat to consider (again - relative to competitors). I have done both St George 70.3 and IMTX and felt the former was tougher - the desert sun is relentless.
iamAERO wrote:
Same, 70.3 worlds in St. George will be awesome. Agreed with everyone above. Fast bikers are generally fast anywhere, but both Texas and StG reward different kinds of fast.
My question is really two fold: to which will the fast age groupers go? and what makes one fast on each course?
Flat and fast Texas should favor age group riders with high watts/cda but their advantage is reduced due to drafting. StG more favors w/kg. So where's the cutoff (w/kg or other) for strong biker on each course that makes one better suited than the other?
As an example, at ~3 w/kg, 240w, what would you think?
Strava
