If your "hooks" were that high your bars would be quite high. For example I have about a 13cm drop. When I ride on the hoods with my forearms parallel the "bulb end" of the brake level is in the palm of my hand and my forearms rest a bit on the top of the bar. For me to get in the same position on the drops as on the hoods I'd need to raise my bars roughly 8-10cm. I'd also probably require a 150 stem or more to get the same reach. Also I'd be using more muscle to hold my position in the drops with nothing to rest on.
Can I ride in the drops with parallel forearms as they are now? Yes, but I have to scoot up on the "rivet" and my head is near the stem. I use the drops to sprint and in crits where control is needed. My arms are bent in the drops, but I'm more aero and can maintain the hoods position for an extended time without much trouble.
devashish_paul wrote:
Rappstar wrote:
Slowman wrote:
i would like to have seen "back horizontal" with hands on tops. seems like all the positions tested are with hands on drops.
Me too. SuperDave told me that during some of the testing Felt did with the then Garmin-Chipotle team, that hands on the brake hoods with back low and arms level was significantly faster than hands in the drops. He said drops were for sprinting, when you needed to pull up for more power.
Would that not depend on how high or high low your hooks are. If you hooks are high enough so that you have back horizontal and forearms horizontal, then that would be equivalent to the position slowman is referring to?
Heath Dotson HD Coaching:Website |Twitter: 140 Characters or Less|Facebook:Follow us on Facebook
