michaer27 wrote:
Hi Chris,
Thanks for posting here and for your work on this product. It seems very exciting!
I am fairly comfortable with GC & Aerolab, but I'm not sure the benefit of using it in conjunction with your Aerolab device. Maybe I'm missing out on the distinction, but I thought from your Aerolab I would get real-time CdA (and other) data which would mean that I would no longer have the limitations of GC's Aerolab to calculate aerodynamics after-the-fact. Plus, with your device I could test many more "positions" by making small changes on-the-fly and see how CdA changes rather than holding one position for several laps, then a second position for several, etc. (When I say positions, I'm referring to even small things like a shrug or hand position.)
The avatar idea is really good for big things like body position and gear, but ideally there should be a way to incorporate small changes, too, like I mentioned above like hand position. Maybe a way to photograph yourself and store the images along with the avatar.
I see myself, after making many big changes, doing some testing as follows:
I ride a circuit with a phone to record my voice and saying, "at 15:45 [minutes into the ride] I am moving my hands both in front of my BTA, right over left. [reading head unit] That looks to improve CdA to 0.241.... At 18:15 I am moving my hands over my computer, right over left. [reading head unit] That lowers CdA...." I would do repetitive tests of all sorts of combinations of hands and head and shoulders, etc. Then afterwards I would go back and examine the data file for the each position (using my verbal notes on which position was at what times). Then after I settle on a position, I could take a photo if I really wanted just to make sure I got all the nuances correct.
I hope that's clear. This is how I imagine I'd use your unit, but I'm a real data junkie (biologist). I'm not sure if it would be used this way by everyone, but I think this is how people would get the most bang for their buck.
Thanks again!
Mike
Hi Mike,
This would be the dream - to see these tiny changes in CdA with slight alterations to hand position etc. in real time. Is that realistically achievable?
The challenge, as with any sensor based measurement, is what is your instantaneous uncertainty in CdA that includes both random errors (noise in sensors) as well as bias errors (e.g., bias in power measurement, road slope measurement, etc.). It is my belief that some changes will be discernible immediately (e.g., a CdA change from 0.255 to 0.275 for example), while others require a longer sample of data or repeated trials to determine the change of CdA (e.g., a change from 0.2550 to 0.2555).
Keep in mind, experimental wind tunnel studies have shown that CdA can change with wind speed (i.e., Reynolds number effects), wind yaw (some wheels actually produce thrust at high yaw angles via a type of sail-effect - this will alter the CdA of the bicycle-rider system), crank position (yes, depending on if you have the pedals at 0 and 180 vs 90 and 270 will change CdA though most of this has been attributed to a change in 'A'), etc.
So, if you are riding along for a couple of minutes, monitoring your CdA, and then change your hand position slightly, you might see some change in CdA, but it will be impossible to determine if it was caused by you moving your hand, or caused by any of the above factors (I did not include all factors here).
I should also note, a change from 0.2550 to 0.2555 is 0.0005. For a cyclist at 40kph (11.11 m/s), and density of 1.2 Kg/m^3, this changing from 1925.4 grams of drag to 1929.2 grams of drag. The difference is 3.8 grams. Guess what weighs in at about 3 grams? A penny.
From a practical perspective, detecting a change in drag on that order of magnitude (3.8 grams) is out of the realm of possibility for most wind tunnel facilities (especially once you factor in the effects of repeatability). It will be unlikely to see any sensor system detect changes on that order of magnitude. We (at AeroLab) are scheduling full scale wind tunnel testing in the coming months to better ascertain the limits of the sensor system. It is a critical piece of information for any consumer.
Chris Morton, PhD
Associate Professor,
Mechanical Engineering co-Founder and inventor of
AeroLab Tech For updates see
Instagram
