Back to the Martin paper
deltaKE = 0.5 * (mass+I/r^2)* (Vf^2-Vi^2)
I : moment of inertia they they say is approx .14 kg*m^2 . That number could go up or down significantly with the wheel set
so with a standard wheel, 1.315kg gets added to the mass, so about 2% for a pro tour rider and not athlete in larger body :-)
Agreed that in your case J(ke) as per your video should be constant from interval to interval.
However, correct me if I am wrong, other protocols (like Shen) will have "lots" of acceleration so more impacted ?
As well in your video, you are fortunate that your slope is constant and therefore you can rely on distance. I personally can't even imagine a course accessible to me where this would be the case.
This is where I bang on my "we need good altitude" drum, because if we do, it opens the doors to all kind of possibilities to test "everywhere" and especially places that have good and bad asphalt.
BTW, we do a lot of the same work (pun intended) and we solve Cda/Crr via Cramers rule. But we calculate using points of well known change in elevation.
PS : I watched your video. Youtube started the video and then paused, queuing up an ad to show me. You could see the AI engine compute "what would be an appropriate ad for a person watching this video ?". It had a stack overflow, caught the excption, corrected itself and continued to show the video without ads.
