burnthesheep wrote:
Oh yeah, they jiggle with bounces.
Otherwise, I'm in the exported file. The file populated gpsLatitude, gpsLongitude but didn't populate gpsSpeed or gpsAltitude. Next up, it also has the altitude and altitudeCorr all as very small numbers. Not like starting at an altitude of 350 feet then it losing tiny bits and gaining tiny bits over your ride. Not sure why, but this seems weird.
In GC Notio my altitude starts at zero.
I thought elevation is from sea level and altitude is from the ground. So altitude for a device on your bike should always be the distance from the road to the device. So the altitude, by traditional definition, should always be zero.
I'm just making sure this is right and something isn't wrong here.
The gps coords are like this:
timestamp gpsTime gpsLatitude gpsLongitude gpsSpeed gpsAltitude 0 0 0 0 0 0 0.25 0 0 0 0 0 0.5 0 0 0 0 0 0.75 0 0 0 0 0 1 0 0 0 0 0 1.25 0 0 0 0 0 1.5 0 0 0 0 0 1.75 0 0 0 0 0 2 0 0 0 0 0 2.25 0 0 0 0 0 2.5 0 0 0 0 0 2.75 0 0 0 0 0 3 0 35.60846329 -78.41419983 0 0 3.25 0 35.60846329 -78.41419983 0 0 3.5 0 35.60846329 -78.41419983 0 0 3.75 0 35.60846329 -78.41419983 0 0 4 0 35.60844421 -78.41413879 0 0 4.25 0 35.60844421 -78.41413879 0 0 4.5 0 35.60844421 -78.41413879 0 0 4.75 0 35.60844421 -78.41413879 0 0 5 0 35.60842514 -78.4140625 0 0 5.25 0 35.60842514 -78.4140625 0 0 5.5 0 35.60842514 -78.4140625 0 0 5.75 0 35.60842514 -78.4140625 0 0
Like this:
altitude altitudeCorr 0.03 0 0.09 -0.08 0.07 -0.15 0.13 -0.15 0.02 -0.11 -0.16 -0.11 -0.18 -0.13 -0.1 -0.16
from google
altitude is used to describe the vertical distance between an object and a reference point whereas elevation is used to describe the height of a place above the sea level
what your Notio is probably doing is using your "start point" as the "reference point" in the above statement,
Measuring altitude/elevation change with a barometer is pretty easy. You grab the barometric pressure a the start point and then there is a formula to go from change in pressure to change in altitude or elevation change.
The problem with a barometer is keep in one position, blow on it in one direction, blow harder in another direction and you will get different readings.
So while some barometers may be able to measure 10cm accuracy, that does not include the error introduced by varying weather conditions.
As well pressure at start point and pressure at current point will drift during the day so you will get drift in your altitude measurement.
It can all be corrected but it's not trivial to do it as precisely as possible. The devices don't care about elevation (as per the definition above), they actually care about change in potential energy that can be measured by different methods.
PS, you can get GPS altitude during post processing if that is of any interest to you.
Also, not sure how you export the file, but there are sections in the GC file that you may have interesting data in
Look for example at the BCVX section. One of these days over beers we will explain what BCVX means :-)
