2018 Speed Concept - Torpedo, computer, and light mount?
I just purchased at 2018 Trek Speed Concept. The LBS and I are having difficulty finding a solution to mount the water bottle, computer, and headlight on my bike.
The real issue is the headlight.
I purchased the water bottle cage that is specifically designed for the Speed Concept. I also purchased the Garmin Edge 820 and the Varia UT800 headlight.
Does anyone have all 3 pieces mounted on their cockpit?
Any suggestions?
Pictures would be great!
Thank you,
Michael
Re: 2018 Speed Concept - Torpedo, computer, and light mount? [NewbieTri100] [ In reply to ]
I would guess that the light is only used in training, and therefore a separate mount for that should be preferable?
I like the Profile Design FC system
http://www.profile-design.com/product/hydration/fc-hydration-system/
It is a BTA setup generic to any aerobars that has an integrated mount bar that I set up my Garmin mount on. You should be able to put something like a BarFly on that to hold a light below and a computer above.
" I take my gear out of my car and put my bike together. Tourists and locals are watching from sidewalk cafes. Non-racers. The emptiness of of their lives shocks me. "
(opening lines from Tim Krabbe's The Rider , 1978
I agonized over this. Ultimately found the Speedfil bottle mount system, with Garmin mount included, to be the best solution
Re: 2018 Speed Concept - Torpedo, computer, and light mount? [minimalist] [ In reply to ]
Yes, the light would be training only. I would like to be able to remove both light and mount when racing.
Michael.
Re: 2018 Speed Concept - Torpedo, computer, and light mount? [Poon] [ In reply to ]
Where did you put the light? What did you use to mount it?
Michael
Re: 2018 Speed Concept - Torpedo, computer, and light mount? [Sbernardi] [ In reply to ]
Sbernardi wrote:
http://a64.tinypic.com/jr7m8o.jpg
Did the Bontrager light come with the band that you wrapped around the bar?
I have the Garmin UT800. It comes with the quarter turn friction mount. The issue is it requires a male connection (like on the back of all the Edge products).
I was hoping that Garmin had the male version of their quarter mount that can be strapped on using the bands the always accompany Edge products.
BTW - Nice bike!
Michael
Re: 2018 Speed Concept - Torpedo, computer, and light mount? [TriDevilDog] [ In reply to ]
Thanks for the suggestions. I'll look at the BarFly products to see if there is a compatible mount.
Michael
Yes. It came with that. Not sure I understand the friction mount part. Has to be a way tho.
http://www.TriScottsdale.org
This is by far the best TT mount I have found for garmin & light or go pro.
https://barflybike.com/shop/bar-fly-4-tt-includes-garmin-polar-wahoo-mio-magellan-gopro-light-copy/
Not sure what bars you are running exactly, so not sure if it will work or not.
-Brad Williams
Website | Twitter: @BW_Tri |Instagram: @BW_Tri | Strava | Co-Founder & Coach at: KIS Coaching
Partnered with: Zoot Sports | Precision Fuel &Hydration | ISM
The UT800 is also compatible with Gopro mounts so if you happen to have one of those kicking around (that you can mount on your aerobar or even on a fork blade), it will work.
Less is more.
Nice color coordination with the frame.
I like the Zipp BTA solution with a xlab gorilla cage bottle holder. http://www.zipp.com/...pvwyf6wsdh1ra1tisjzd
IS that the TT mount for the pioneer power meter computer sgx-ca500 . I tried to put it on my Speed concept and it would not fit between the bars.
Re: 2018 Speed Concept - Torpedo, computer, and light mount? [wildcats1] [ In reply to ]
Yea I had to really wedge it in and slightly angle. Think I also removed some bar tape. Old bike n setup. Now 520 w a profile design mount bta
