I know that SRAM recommends against going 1x without a clutch RD. I know people have hacked together 1X systems without a clutch RD with positive results, but others have had negative results (chain drops).
I’m stuck trying to understand why using a chain guide attached to the braze-on mount, combined with a narrow-wide chainring, wouldn’t prevent a chain from dropping, or at least be AS successful at keeping the chain from dropping as a front derailleur is on a 2x system.
On a 2x system, the front derailleur isn’t adding tension. It can prevent the chain from moving too far left or right, or even upwards, but that’s it. A chain guide that sits over the chainring like a FD would do the same thing…it would keep it from dropping to the left or right, or from jumping upwards and off. If anything, the guide could be adjusted to even closer tolerances than a FD. Paired with a narrow wide ring, how would that be worse than a FD on a 2x system? Even if the chain bounces off the bottom of the chainring because of slack caused by the RD, the chain should remain on the narrow wide ring as the top, and pedaling should get the chain back on, right?
I guess if/when the chain drops on a normal 2x, you can shift the FD to help get the chain back on. That’s the only advantage I can think of that a FD would provide over a chain guide.
I have the original eTap on my gravel bike. I want to ditch the front derailleur because the battery is the limiter to my tire clearance. There is not a clutch RD that can be paired with the original etap levers.
My other thought is that I could run a bar end shifter coming out of my drop handlebar that connects to a regular Red FD. That would allow me to keep using eTap levers and RD, but I could still keep my 22 gear combos and not have to worry about dropped chains from not having a clutch. But, that would be pretty ugly.
Any thoughts before I spend about $120 to buy a 1X chainring and chain guide? Wolf, Praxis, and K-Edge all make chain guides that connect to the braze on clamp.
edit: here is a photo from Wolf Tooth:
