1x Chainring availability
 What brands of 1x specific chainrings are available?
Do any of them offset the chainring so that when bolted to a conventional 2x crankset the chain line will be centred with the rear cassette?
Re: 1x Chainring availability [DeanV] [ In reply to ]
Absolute Black
http://absoluteblack.cc/aero-sram-direct-mount-oval-criterium-chainring/
Sram (obviously, anything from low cross gear to 52/53/54 I believe)
https://www.sram.com/...ram-force-1-crankset
I keep hearing Rotor has a narrow-wide-Q ring, which sounds perfect but can't seem to find it
There's also the AeroCoach Arc.
Re: 1x Chainring availability [Grill] [ In reply to ]
If you win the lottery
Rotor makes QX1 in 46,50,52
They also make a 1X spider for their cranks which helps with chain line.
http://www.cart32hostingred.com/...amp;prodid=265728010
Re: 1x Chainring availability [TriByran] [ In reply to ]
yet less than a shimano 9000 ring :)
Looked at potentially other options but I run a 54. Using the good old trusted and true Sram X-Sync and see no reason to switch.
Save: $20 on Air Relax Recovery Boots| $100 on Normatec| 15% on The Most Absorbable Magnesium | Best $50 Indoor Cycling Desk
Blogs: 2018 Normatec Pulse vs 2015-2017 Normatec Pulse | QUICK Air Relax Travel Case Review | Q1 2018 Blood Test Results | Why Latex Bikes Tubes | Vittoria Corsa Speed Aero Data | 10 Reasons To Consider HED JET+
Worth mentioning Garbaruk, especially for non-standard tooth/BCD combinations. When I was looking for a 48T narrow/wide ring to go on a 130 BCD spider (for an old SRM I have) it was the only company I found who could supply one.
Re: 1x Chainring availability [Thomas Gerlach] [ In reply to ]
Also Fiberlyte carbon fiber rings, not narrow wide but with the taller teeth they reportedly have good chain retention. About $115 US depending on exchange rate.
http://www.fibre-lyte.co.uk/..._chainring_2011.html
Re: 1x Chainring availability [Anachronism] [ In reply to ]
Have a few of these and have used them very heavily. An excellent product, with excellent chain retention.
The land of $15,000 bikes and a £135 chainring that was specifically developed for your discipline is considered too dear? Seems thin.
Is chainline an issue with the Fibre-lyte chainrings? Anybody know if they work with the SRAM hidden bolt designs?
Re: 1x Chainring availability [blackey] [ In reply to ]
Never had a chainline issue. They work with SRAM you just might have to specify when you order.
Just to mention, we (Absoluteblack) have a new 52 and 54t 1x DM aero ring scheduled for production in the next 4-6 weeks at our factory. It will fit directly onto SRAM Force/Rival cranks with no added parts or spacers required for perfect chain line. Keep an eye on http://www.absoluteblack.cc
I'll do my best to ping you when they're in stock.
Cheers,
AB
Re: 1x Chainring availability [Absoluteblack] [ In reply to ]
Any chance we will see an oval, 5-bolt, 52-54 tooth, narrow-wide, aero chainring?
I tried a Fiberlyte and didn't find that it held the chain as well as the narrow-ring. As a consequence, I have a Fiberlyte that I would sell for 80$ if anyone is interested. PM me
Re: 1x Chainring availability [grumpier.mike] [ In reply to ]
X2
AeroCoach Arc does a 54t. Not traditionally ovalized per se, but not round (shape was specifically developed for TT type efforts).
Our alu 52t triathlon specific shaped rings are hopefully about 4-5 weeks away. Slightly different gearing pattern than the carbon 54s that we do.
AeroCoach UK
http://www.aero-coach.co.uk
Also, what about a 52 110 bcd ring?!
My Blog - Twitter - Instagram - JonnyO Coaching - ICE Friction - SLF Motion - Greater Than Sports Drink -
Am i correct in concluding that the only powermeter option for direct mount absoluteblack rings would be stages? Also, just to confirm, it does not fit on Red cranks?
thanks!
Hey! Is there any update on availability of the 54T DM aero 1x ring from Absoluteblack?
Re: 1x Chainring availability [jakesdk] [ In reply to ]
I have one on my P5 now. Rotor QX1 in 52T.
Race Director, Velo Club La Grange (http://www.lagrange.org)
X-Sync is a great 1x option for round rings. It perplexes me that with plenty of X-Sync options, from 50T to 52T to 54T, Tririg chooses to spec a 48T chainring on its Omni complete build. We are supposed to go fast on our TT bikes, aren't we?
Re: 1x Chainring availability [refthimos] [ In reply to ]
Just to be clear....48 X 11T @ 90 rpm (that should be the low end of your cadence for a steady effort) is 30.8 mph.
http://www.sheldonbrown.com/gear-calc.html
