can't find an answer to this anywhere online. can wolftooth 1x chainring bolts be used/fit on a sram x-sync ring? if it helps, here's my situation. I had a 1x setup with 105 5800 cranks, a 4-bolt wolftooth 1x ring, using 4 wolftooth 1x bolts. I have a new bike which is 2x with a praxis 110 bcd 5-bolt crank. If I buy a sram 1x ring which comes with the hidden bolt, can I use the 4 wolftooth bolts i already have to complete a 1x setup on the 5-bolt crank with sram ring?
thanks
thanks
