rruff wrote:
But your reasoning implies that we should all be on low stack frames, because adding height to aerobar risers is more aero than a taller headtube. Is this true?
Yes, generally this is true. There have been a number of threads on ST to this effect. But, it is within reason, because the bike has to fit and be functional for its rider. For example, if you picked a frame two sizes too small, you might need a crazy long stem and extra long seat post. You cannot arbitrarily pick a frame size without other impacts.
But, the above is moot. Cervelo geometries are the same for P2 & P5. There was no functional excuse to test two different size bikes. If Nick was really going for a true frame-to-frame argument, he would have tested the same size. But, he did not have two bikes of the same size, so he wiffed it. Also, we do not know to what extent the P5's Aduro cockpit contributed to the drag difference. Best Case, the test may have made an argument that the Alpha X is more aerodynamic than the 3T Aduro. I get that he could not test everyhting, but without any controls, and two different frame sizes, and two wholly different cockpit configurations, the results are mush.
Caveat: I have a lot of Tririg stuff, and I totally love it. I am not a Tririg hater, just a hater of that silly test and its false conclusions.
