http://www.slowtwitch.com/...ops/Xantusia_46.html
Bjorn is there now and has posted some photos: https://www.instagram.com/bacoaching/
Monty - kidnap him and keep him for another week!
You're coming from Ontario right? You might want to print this out. If you're coming from the west side - see the link above about coming from the #14.
FROM THE #15
About halfway up the Cajon Pass on #15 you'll come to an offroamp for highway #138. You'll take this road west (left turn off the freeway). You'll spend about 25 minutes on the #138, and after spending most of this time traveling through the flattish Antelope Valley you'll eventually come to 165th street (there will be signs alerting you that this is the turn-off for Crystalaire and Valyermo).
FROM THE INTERSECTION OF #138 AND 165TH
You'll turn "uphill" from here, toward the mountains. That's "left" if you're coming from the #15, and it's "right" if you're coming down from the #14. It is a good idea to set your trip odometer to zero at this point. After ascending almost exactly 5.0 miles, STAYING ON THE PAVED ROAD, you'll reach the top of the grade. There's a green wrought iron gate on the left, it's always open. You'll go through here and onto a dirt road. Travel 3/10 of a mile, do not turn anywhere, and you'll see a second black wrought iron gate. You're here (sort of). Turn left and follow the fence line, keeping the fence on your right shoulder. After several hundred yards, you'll see a yellow house on the left. That belongs to Mark Montgomery and is likely where you're staying. The property on the right, inside the fence, is where you'll attend the workshop.
Most important: Do not Mapquest! If you do, you're liable to take a very scenic route that will lead you high in the mountains, and to both seasonal and permanent road closures. Use the directions we provide above.
clm
Nashville, TN
https://twitter.com/ironclm | http://ironclm.typepad.com
FROM THE #15
clm
Nashville, TN
