Trek speed concept Gen 2 Small 9 series P1 vapor coat black used from 1 season condition near mint includes $2600
Sram XG-1099 11-32 a pair cassette for $110 sram only one used in wet condition the other in dry
Sram XG-1190 11-32 used ones for IMLP $180
Trek speed concept XL 9 series Gen 2 used from 2018 to Pink green and black present $1350 sold pending payement
Trek speed concept medium gen 1 7 series fork and frame draft box rear integrated brake, gxp BB and headset $400
Trek Speed concept components
New trek speed concept / trek ttx compatible carbon offset seatpost 48mm $70
used trek speed concept / trek ttx compatible carbon offset seatpost 48mm $50
Trek speed concept speedfin 3 available flat black, gloss black and flat black with yellow trim $60
Bontrager Duotrap bluetooth version ( just the duotrap no magnets included ) $30
Trek Speed concept cam foil version 1 titanium front and rear skewers $55
Trek Speed concept gen 2 titanium front and rear skewers $65
Trek Speed concept gen 2 standard version front and rear skewers $40
Trek Speed concept lot of 2 front skewers standard gen 2 and gen 1 titanium $20
Bontrager stub ( stem convertor to use a standard stem) $20
Chain ring & cranks
SRAM X-Sync 54T 130mm Chainring for a 1x system used for 2 40k prologues $40
vision aero ring used with sram inner ring new bcd 110 50t/38t $40
Sram red etap hidden bolt 170mm bcd 130 gxp new take off $120
Sram red exogram 167.5mm bcd 130 gxp new take off $120
Sram red etap 162.5 crank removable spider 8 bolt version did not fit the athlete turned in in for a 165mm after a week $350 or with bcd 130 dzero $750
Sram force 170mm crank gxp bcd 130 $50
Other Components
Tririg Sigma x stem used $120
Tririg omega x brake $120
Shimano 105 pedals gently used $30
Shimano 6800 new take off front brake calliper no pads $25
Shimano dura ace 7700 brake callipers if great shape $30
Sram etap firmware updater stick new $15
Sram etap charger power adapter for international travel 2 usb slot wall charger with 4 plugs for different regional standards new $30
Sram etap 3 plugs for different regional standards for etap charger new $25
Sram etap Blipbox and shifter plugs to protect from the elements lot of 10 units new $15
Sram etap cover to protect battery from element and charge indicator lot of 9 units new $20
Sram etap front derailleur shim kit new $20
powertap battery cover tool old version $10
powertap battery cover tool new version $10
torhans aero z without the straw $15
bontrager Torqkey 5nm $10
Token aero Skewers 42g removed with a tool claimed 3w saving single tool version used $40
Token aero Skewers 38g and no lever removed with a tool claimed 3w saving single tool version used $40
Fsa gossmer brake calliper $15
Hed flame rouge hub spare parts ( no hub body ) $15
mavic ksyrium anniversary edition hub excellent condition 10/11s 20h $30
Crank brothers lot split skewers new without box and cobalt stem 90mm new in box $50
Bontrager paradigm R saddle and kovee lot of 2 new saddles $60
Skewers
Bontrager RL skewers black with sliver tips $20
Bontrager RL skewers black with black tips $20
Bontrager Aeolus Skewers black $20
Super type titanium skewers silver $20
Hed titanium Skewers flat black set new $30
Hed titanium front Skewer flat black new $15
Hed silver with with black tips titanium Skewers used $20
Hed silver with with silver tips titanium Skewers used $20
Hed single front silver with silver tip titanium used titanium $10
Zipp silver with with silver tips titanium Skewers used $20
Token aero Skewers 42g removed with a single tool claimed 3w saving single tool version used $30
Token aero Skewers 36g removed with 2 tools claimed 5w saving single tool version new $40
Mini group
Sram red 22 mini tt group
trp carbon brake levers
r2r bar end shifters
red yaw 11s front derailleur
red 22 rear derailleur
used but in great condition cosmetically and mechanically
$275
Armstrongj: Mar 2, 20 12:05
