Specialized Diverge Smartweld 52cm, Ultegra, Carbon Wheels
52cm Specialized Diverge Comp road/gravel bike. Specialized aluminum smartweld technology. Bike has low miles, in good shape all and all. A few paint chips but no dents or big dings. One of the best all around bikes out there, can fit up to 700x35mm tires and I had 38mm 650 tires on it at one point. This could be the one bike to rule them all. Fork is 15mm, rear is 135mm quick release (not Specialized's dreaded SCS, only the carbon models got that technology). I believe it's a 2015 or 16 model. Bike has a few upgrades from the stock specs below, carbon clincher wheelset from Taiwan 40mm dep, 26mm wide o-o, Vittoria Corsa tires 700x25, Forte carbon seatpost, generic Power saddle 143mm. Had a tune up and brake bleed about 6 months ago. New rotors. Great value for what you are getting. I don't own a scale, no idea on weight. No pedals, no gopro mounts, and a different set of cages will be included.
Dimensions Stack 544mm, Reach 378mm, Head Tube 120mm, Actual Top Tube 53.6
$1300 shipped within lower 48. Add $75 to Canada. No trades, not really that flexible on price.
Full Specs:
CHAIN
KMC X11, 11-speed, reusable Missing Link
CRANKSET
Praxis Works, TURN Zayante, BB30, 50/34
SHIFT LEVERS
Shimano Ultegra 685
FRONT DERAILLEUR
Shimano 105, 11-speed,
CASSETTE
Shimano 105, 11-speed, 11-32
REAR DERAILLEUR
WHEELS
REAR WHEEL
AXIS 3.0 Disc
INNER TUBES
Standard, presta valve
FRONT TIRE
Specialized Roubaix Pro, 120TPI, folding bead, BlackBelt protection, Endurant casing, 700x30/32c
REAR TIRE
FRONT WHEEL
AXIS 3.0 Disc
COCKPIT
SADDLE
Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
TAPE
Specialized Roubaix, w/ 2.5mm gel pads, bar end plug
SEATPOST
Specialized CG-R, FACT carbon, single bolt, 27.2mm
HANDLEBARS
Specialized ergo, 42cm
STEM
Specialized Comp Multi, 3D forged alloy, 4-bolt, 12-degree rise
BRAKES
FRONT BRAKE
Shimano 785, hydraulic disc, Ice Tech resin pads w/ fins
REAR BRAKE
ACCESSORIES
PEDALS
Nylon flat test ride, loose-ball, w/ reflectors
FRAMESET
HEADSET
1-1/8 upper, 1-1/4"" lower, Campy style, crown race, 8mm carbon cone spacer, w/ 20mm of carbon spacers
SEAT BINDER
Alloy, 31.2mm
FORK
Specialized FACT carbon w/ Zertz, tapered
FRAME
Specialized E5 Premium Aluminum w/ D'Aluisio Smartweld technology, tapered headtube, OSBB
Re: Specialized Diverge Smartweld 52cm, Ultegra, Carbon Wheels [CannonCam] [ In reply to ]
PRICE DROP $1200
