61cm Venge Vias roller. It will come with everything you see in the pictures, EXCEPT FOR THE CRANKSET. Throw on a groupset and you’re ready to ride.
2016 venge vias module, fact 11r carbon layup
Roval CL64 clinchers with s works 24mm tires
S-works vias bars 42cm, 25mm rise and integrated garmin mount
Two stems, 105mm and 125mm
Extra set of brake calipers
143mm specialized power saddle with carbon shell and ti rails
Frame is in perfect condition aside from a couple small paint chips that you can see in the pictures.
You will need to buy a headset, headset spacers to reach desired stack, seatpost clamp, and a couple cheap pieces for the inside of the stem to complete the internal routing system unless you’d prefer to run a regular stem and bars on it then you don’t need anything other than the headset. These parts can be ordered from your local specialized dealer.
Seatpost has been trimmed down so max saddle height is right around 805mm from bottom bracket to center top of this particular saddle.
I was going to build this up but I’ve got another project and need to free up some money.
3000/OBO and buyer covers shipping costs via bikeflights.com
2500/OBO and buyer covers shipping costs via bikeflights.com
[url=https://ibb.co/hQM98n][/url]
[url=https://ibb.co/b4BnuS][/url]
[url=https://ibb.co/bCyNTn][/url]
[url=https://ibb.co/cJPU8n][/url]
strongbear0: May 13, 18 11:22
