Lots of new parts on this including carbon crank, cog, bar tape, bottom bracket, and new never used Stans valve cores if you want to go tubeless.
Asking $1,000.00 Shipped
SOLD FOR $960.00 Shipped
Build is as follows:
Weighs: 17.35lbs as pictured
Frame: Traitor Crusade Single Speed (2011-2012)
Frame Material: Steel (Columbus Life Tubing)
Frame Size: 55cm
Fork: Columbus SLX Claymore
Crankset: SRAM Carbon S952 (172.5mm) GXP
Chain Ring: Wolftooth 40T Direct Mount
Rear Cog: Wolftooth (18T)
Brakes: TRP Energy Canti
Front Wheel:Stans Alpha 340 Rim(Tubeless ready with tape installed & valve stems included, Velocity Hub, Velocity QR
Rear Wheel: Stans Alpha 340 Rim(Tubeless ready with tape installed & valve stems included, Chris King Classic ISO Singlespeed Hub with Funbolts!!
Tires: Clement MXP Clinchers
Tubes: Vittoria Latex
Stem: Ritchey WCS Wet White 110mm +-7 degree
Handle Bars: Ritchey WCS Wet White Alloy Drop (42cm I think)
Handlebar Tape: Supacaz (new this season)
Saddke: Fizik Arione
Seatpost: Ritchey WCS Wet White 27.2 with setback
Chain: SRAM 1090
HeadSet: Chris King
Bottom Bracket: SRAM GXP (new)
Bottle Cage: White, new
Pics:
Frame Size: 55cm
Chain: SRAM 1090
HeadSet: Chris King
Pics:
