grayskinner: Jun 11, 18 17:56
Classifieds
Post deleted by grayskinner
Re: FS: Speedplay, ROKA, Torhans AeroZ, Phenom Saddle, Shimano PRO aerobars, stem, BB, Stem, Dura Ace [grayskinner]
I have a 2015/16 Shiv they call a OBSS bottom bracket with a BB30 FSA crank. Do you know if your BB for sale would work for this setup?
PM Sent
Re: FS: Speedplay, ROKA, Torhans AeroZ, Phenom Saddle, Shimano PRO aerobars, stem, BB, Stem, Dura Ace [tomk407]
Thanks for the question, i assume you mean OSBB.
I used this to run my 2012 FSA SRM on my 2017 Specialized Allez Road bike.
basically it lets you run a standard 24mm crank on a BB30 frame.
Based on reading this - https://www.kogel.cc/...lized-osbb-explained - the 2015/6 Shiv should be a candidate for this BB. Hope this helps.
From the product spec -
Wheels Manufacturing's new BB30 to Outboard bottom bracket is designed for installing 24mm (Shimano, FSA, Etc.) cranks into BB30 frames without the need for any adapters.
- Weight: 153g
- Made in the USA
- Enduro ABEC 3 sealed bearings
- Dual silicone seal keeps the contamination out for longer life
- Will accept current 24mm (Shimano, FSA, Etc.) cranks
Re: FS: Speedplay, ROKA, Torhans AeroZ, Specialized Phenom Saddle, Shimano PRO aerobars, stem, BB, Stem, Dura Ace [grayskinner]
What model is the DA crankset? Also what size rings?
Re: FS: Speedplay, ROKA, Torhans AeroZ, Specialized Phenom Saddle, Shimano PRO aerobars, stem, BB, Stem, Dura Ace [trimdc]
Great question, 53/39, FC9000
Re: FS: ROKA, Skechers, Torhans AeroZ, Specialized Phenom Saddle, Shimano PRO aerobars, stem, BB, Stem, Dura Ace, Speedplay [grayskinner]
Is it the 85mm Pro Missile Evo stem or the longer one?
Re: FS: ROKA, Skechers, Torhans AeroZ, Specialized Phenom Saddle, Shimano PRO aerobars, stem, BB, Stem, Dura Ace, Speedplay [TriFluid]
Good question, 170mm total length, effective length c to c is 90mm
Awesome stuff. PM Sent.
Re: FS: ROKA, Skechers, Torhans AeroZ, Specialized Phenom Saddle, Shimano PRO aerobars, stem, BB, Stem, Dura Ace, Speedplay [jasonwiener]
thanks items going out tomorrow.
updated items and prices.
How narrow can you get the pads on the aerobar?
Terrible Tuesday’s Triathlon
Re: FS: ROKA, Skechers, Torhans AeroZ, Specialized Phenom Saddle, Shimano PRO aerobars, stem, BB, Stem, Dura Ace, Speedplay [oscaro]
9.5 cm internal, 26.5 cm external at the narrowest setting.
bump
bump prices reduced
