Post": In Reply To:
At the bike shop I do fitting for, we have seen several instances where riders have rolled tires using just Tufo tape without glue (I rolled two tires in a single cross race myself.) I would highly recommend a light coat of glue on both rim and tire before using the tape. Zero rolled tires doing this, in our experience.
I can't believe this is possible if the tires were mounted using the tape properly. I'm a fairly big muscular guy (as triathletes go), and I fought like crazy to get a Tufo tape mounted new tufo tubular off my acetone cleaned hed disk. Even then, the tape had only come off the rim, not even a bit off the tire itself. I've never had a glue mounted tire that was anywhere near that tough, and I've tried nearly all the glues out there.
I doubt that Tufo would recommend additional glue to improve mounting strength.
Dan " Believe what you like, it's the truth, and yes, the tires were mounted properly. I actually know much more than the average joe about adhesives - I used to work with them for a living.
Tufo is not the only, or the first, manufacturer to offer adhesive rim tape for tubulars, and it has ALWAYS been accepted practice to apply a light coat of glue to the tire and rim before taping. The cotton tape surface of a good tubular, in particular, can be difficult for glue to adhere to without doing this first. In every single failure of the tape that I have seen the tape remained on the rim, but peeled away from the tire (as happened when you removed your tire, by the way.)
"Iwould think that adding glue will prevent the tape from bonding to the rim, rendering it useless.
I would contact tufo, until then DO NOT USE GLUE AND TAPE AT THE SAME TIME!
You are doing something wrong if you are rolling tires that often. I know guys screaming around the track and on crit courses at very high speeds on this tape. "
Why would you think that rim cement would prevent the tape from adhering to the rim? Serious question, I would like to know if you have anything to back this supposition up - I can offer some pretty good reasoning to the contrary, but honestly, I think that the rim surface isn't very problematic for the tape, it has a harder time adhering to the base tape, and this is where a wash coat of glue really helps..
Did you contact Tufo to ask about wetting the rim tape surface? This is a potentially horrible idea, depending on the adhesive used in the tape. I'm not saying it is a horrible idea, just pointing out that it could be - but I bet you didn't call to ask them...
Contrary to popular belief, the track just isn't that hard on tubulars - hell, most track riders swear by Fasttack, and that's been proven to have very low bond strength in this application. Crits are a different story, potentially, But I have glued literally hundreds of tires, and only rolled 3, two using Tufo tape, and all three in 'cross races.
I can tell you exactly why and when we have seen Tufo tape fail: in very heavy rain, with round carcass tires mounted to V shaped tubular beds - specifically (and ironically...) Tufo tires on Zipp rims. The failures appear to have occurred because: 1)the adhesive used appears to be somewhat water soluble, or at least loses bond strength when the base tape becomes saturated, and 2) the bond of the tape is very dependent on the profile of the tube matching that of the rim - a tire with a carcass shaped like "U" does not work well in a rim-bed shaped like "V" - which makes sense, as the Tufo tape is pressure activated.
The two tires I rolled were, as I said, cross tires; in pouring rain, with the tires inflated to a whopping 28 PSI on Zipp rims. This is pretty much the ultimate test for tubular adhesion, and the tape failed. Does this mean that the average triathlete has to worry about Tufo tape? No - but it's good info to have, and the product is not the foolproof/worryfree/brainless solution to tubular mounting many people think it is, and it may be a very bad choice for certain tire/rim combos. I stopped using the stuff on my cross tires - which was an expensive decision, as Tufo was giving it to me for free - and saved it for the TT/tri bike (conti on Zipps,) and have had no problems (knock on wood...)
MH
MH
Coaching and bike fit -
http://source-e.net/ Cyclocross blog -
https://crosssports.net/ BJJ instruction -
https://ballardbjj.com/
