Trivial question and an attempt to be "tri-oriented:"
I have run into a deal on a 2003 Guru Crono 53cm and I am guessing it's my height by the 2004 measurements (I am 5'10", 165lbs, 31" inseam, longer torse is likely w/ 53-54 top tube). Was fitted on a Serotta Fit bike last year but not sure how keen I am on the fitting as the fitter had the aerobars jacked up so they were almost more vertical than horizontal. I think he thought the aerobars we to act more like a bumber-tv antenna-bookholder.
At any rate, I will likely be able to get the 2003 bespeckled with DA10 as opposed to a 2004 w/ Ultegra9. . .what would Tom do?
_________________________
"For there are brighter sides to life and I should know because I've seen them but not very often." -Morrissey
