DrAlexHarrison wrote:
Jim@EROsports wrote:
a properly shaped and sized storage device that partially supports the athlete's weight is very compelling.
My wife has been asking for this for years. As soon as she heard what RAAM was in ~2020, it started coming up.
No offence to anyone on this, but no no no no no.
1st, that's what tri-bars initially were there to do. Your body was supported by the fixed point of your saddle at one end and then the upper arms were the other end that was supported by the elbow at 90 degrees. That and a strong core to resist the rotational reaction to your thighs rotating meant you were able to sustain the position for the duration of the ride.
My take is that at present there is a balance between the non-restrictive positional rules of triathlon to get a comfortable position and one that is all out aero. Start adding in supports and we rapidly acclerate to a full prone 'missile' position where the only limit is the shape of your forehead/eye sockets for visibility.
(and this is the bit I don't want to be taken as an attack on any individual) As it stands, then if someone is feeling that they need upper body support in a position the solution isn't a structural add on to the bike, but either changing position to bring the elbows back or spending more time doing pilates/strength work.
For me what I think would be awesome but won't happen for the next gen superbikes (we saw it briefly in early current gen) was improved packability. Had a discussion yesterday AM and I mentioned flying with my old titanium frame in a soft case without a lot of worry. This against someone's SC that got smashed in a SCION case.
I worry that proprietary integration of 'garmin' data into displays in the bars/frame with powermeter/DI2/CDa to get away from external mounts. I also suspect we'll see more work on vibration damping/suspension. Got that with Trek and the IsoMount, but see that beign expanded.
And of course the ability to run 60mm wide tyres on rimless wheels at 15psi ;-)
