New in box Shimano ProVibe EVO carbon bar
WEIGHT from 390 grams MATERIAL T700 Carbon WIDTH 40 cm STEM LENGTH 105mm STEERER TUBE 1 1/4 inches (1 1/8 inch with shims)
The PRO Vibe EVO Carbon Bar/Stem Combo is an integrated piece that remains comfortable despite its aerodynamic focus. It is made out of T700 Carbon which helps the bar remain lightweight in addition to its comfortable aerodynamics. The grips on the bars are replaceable and seamlessly flow into the hoods, eliminating the need for bar tape. Five different ergonomic hand positions are available using the bar, allowing your hands to naturally move as you ride. It is optimized for Shimano Di2 shifting and compatible with internal or any other type of cable routing. Shims are included, allowing you to move the stem 2 degrees in either direction based on personal preference. The PRO Vibe EVO Carbon Bar/Stem Combo is a great way to upgrade the integration of your road bike.
https://photos.app.goo.gl/1VAjyhsnhiqAXo4q7
https://photos.app.goo.gl/5LcQwdz5xkMGLg719
andrewblerner: Jan 8, 23 10:05
