pk1 wrote:
gary p wrote:
turdburgler wrote:
Looks like we've got another set of quick tires out there. Anyone have any experience with these (coming from someone who has never ridden Michelin). https://www.bicyclerollingresistance.com/road-bike-reviews/michelin-power-cup-tlr
Edit: Just noticed the recommendation for mounting this on rims with 15 - 17 mm inner width...which makes this not suitable for me anyway. That recommendation is based on the narrowness of the tread relative to the casing, and the possibility that you might be off the tread if you're leaned way over in a hard corner. Seems more of a crit-racing or kamikaze road bike descending issue than a triathlon leg issue.
the photos show
- quite a wide textured band down the middle
- a shoulder section of seemingly the same tread rubber but not textured
- a seam then the sidewall proper
you're not going to touch the sidewall itself at any normal cornering lean, though you might get it close enough to the ground to expose it to gravel and class
the question to me is about that middle section which is very much standard cornering surface - why is it so differentiated from the central area (in the reverse way of what we often see) and what does that mean for grip and protection when cornering?
from what i understand, this pattern of textured centre and smooth shoulder is typically not good aerodynamically either
I have this tire and there is no texture on the tread. Are you looking at the right tire?
I am firmly in the camp of "its enough tread" for a majority of riders. It's the same as Corsa Speed and people aren't worried about that one. If Jarno (BRR) hadn't mentioned it, I doubt many would've noticed. However, there are some people who lean past that point on these tires. From another forum:
