mdana87 wrote:
First, whatever you’re testing there, integrated extension cup/pad setup, looks amazing. When might we get more info or be able to get these under our arms?
Quote:
Second, ‘22 Felt IA Advanced AXS… is it possible to mount an HSF Aeria up front?No you wouldn't be able to use the HSF faceplate on the Dagger stem, it hasn't been tested.
As to whether the tri stem would work - I don't have a contact at Felt anymore to ask. If the cover is size specific and you have a large size - maybe. But looking at the above image I think it would be unlikely as the bottle would probably contact the top of the fork.
Quote:
Also, I’m this “” close to ordering the Wing 20c+ kit with ASC extensions, assuming what you’re testing won’t be available by June ‘24. Considering the above, any issues to be aware of?The Wing20C+ would work well with the Dagger stem - allowing cables to route through the bar into the stem. With ASC extensions you can achieve a very tidy and comfortable setup.
For hydration you probably need to look at a BTA, there will be one suited to the ASC available later in the year.
