Not fancy, but works. I need to smooth the edges to curved, later.
But now I can have any pad width I want within reason and any toe angle I want within reason by just loosening the underside screws. I also tapped the plate in more than one spot. So, you can leave the extensions bolted up and gain/lose about 1" of reach. If you unbolt the extensions you can rotate the plate 180 degrees and have another pair of fore aft reach coords. But I can still adjust reach via the poles also anyway.
