doctorSpoc wrote:
Well the other thread was about Silca pressure calculator.. which Tom A acknowledges is shown to be essentially just a guess... imo, useless actually because the input of the calculator are not actually correlated with optimum pressure.. do you see Tom arguing that my assertion that tire width or crr are not correlated with optimal pressure is incorrect..?
Examples..
Pirelli Zero Race TLR (TL) - 28 and 30mm had same breakpoint pressure
Vittoria Corsa Control 2.0 graphene (tubes) 30mm break point was lower than 28mm
Another claim you make is also appears to be incorrect.. in EVERY case where the same tire is tested in two sizes at optimum/breakpoint pressure the 30mm aways rolled better (less watts) on a textured drum.. same pressure or lower...
stevej wrote:
doctorSpoc wrote:
Yes... still not correlated..
stevej wrote:
You do realize that when Iām talking a narrow tire vs a wide tire I am talking about the same exact tire but just different widths right? Eg: a Conti gp5000 25 mm vs a Conti gp5000 28 mm. Sorry if that wasnāt clear.
Itās a completely different story if Iām comparing a 25 mm Conti gp5000 25mm tire vs Schwable pro one tt 28 mm.
I donāt see anywhere in the other thread you linked that debunks this. Would love the read the vn article but Iām not about pay for it.
I wonāt argue the silca tire pressure calculator is perfect. Josh has stated on podcasts that they are actually trying to solve for the breakpoint pressure but it is also just a starting point. People want to argue with them over the validity of the calculator and I honestly donāt know why. If you have data that says thereās a better pressure for your setup, great then go with that. They are providing free information to the masses that is based upon various testing. No one else is doing that and they should be commended for that. Most people donāt have the knowledge or capability to do their own testing.
Just because someone didnāt argue with you on a point you made doesnāt necessarily mean your point is accurate. I canāt speak for Tom so I have no idea if he actually agreed with you.
I would like to see the data on the pirelli and vittoria tires you mentioned. The vittoria tire data would seem to support my theory.
What are you considering break point pressure on a textured drum? I never said a 28 mm would roll faster than a 30 mm at the same pressure. I think we all know the 30 mm will roll faster. But would you not agree that if you continually lower pressure on the 30 mm tire, at some point the crr will increase to roughly the same as the 28 mm?
blog
