Lavender Room
Post deleted by spudone
Re: 68% of Republicans think that Biden sould be impeached... [trail]
you think they won't et them in the election or if elected they won't impeach. It would be mildly entertaining to watch the USA play a game of pong every four years impeaching the other sides President!!
Re: 68% of Republicans think that Biden sould be impeached... [stevie g]
stevie g wrote:
you think they won't et them in the election or if elected they won't impeach.The GOP isn't going to reach 67, even in the most optimistic scenario. And even if they did, there are half a dozen or so non-Trump GOP Senators. So no way 67 will vote to impeach happens.
But per your suggestion, the Nazi brownshirt method would be to take advantage of the rule that you need 2/3 of the Senators present, and 2/3 of those present are needed to convict.
So you only let the GOP Senators in the chamber while you keep the Democrats locked up in the basement. Makes it easy to get to 2/3. Then you impeach Harris and Pelosi.
Will they go through the process in the reps, just for the theatre of it and to build momentum for the 24 election?
stevie g wrote:
Will they go through the process in the reps, just for the theatre of it and to build momentum for the 24 election?I would guess it won't happen. There might be 50-60 GOP House members who really push for it. But I tend to think the adult side (if I use that term flexibly) wouldn't really want to go through with it. As sometimes Trumpy as McCarthy is, I think he understands the pitfalls. (assuming he becomes Majority Leader, which isn't a given).
Hope so, at some point Congress should focus on governing the nation and stop fighting the other side
stevie g wrote:
Hope so, at some point Congress should focus on governing the nation and stop fighting the other sideDuh!
Re: 68% of Republicans think that Biden sould be impeached... [gofigure]
gofigure wrote:
I'm not sure they know there is a difference. They've convinced themselves that they need to defeat the radical socialists to keep them from destroying the country.
Re: 68% of Republicans think that Biden sould be impeached... [spudone]
So they want a President Harris? I wouldn’t if I was a GOP strategist. It’s just mob rules payback with no actual thought behind it.
Duh indeed but they don't
Just like triathletes over bike under train and over estimate their FTP and moan when it all goes wrong, Duh
Re: 68% of Republicans think that Biden sould be impeached... [Patrick_M]
Patrick_M wrote:
So they want a President Harris? I wouldn’t if I was a GOP strategist. It’s just mob rules payback with no actual thought behind it.Just because you think he should be impeached, doesn't mean you will if you know the outcome will be worse for the country.
Re: 68% of Republicans think that Biden sould be impeached... [B.McMaster]
B.McMaster wrote:
Worse for the country or worse for the GOP? A President Harris would bring out the voters in the 2024, and high voter turnout more accurately represents the will of the people, which by default is good for the country.
Harris' numbers are worse than Biden's. If Biden is setting her up for the Presidency he is doing a bad job not that she is helping. Putting her in charge of solving immigration and border security was a no win situation. Many of her key staffers leaving because they cannot work with her isn't helping.
It looks like they moved her off immigration and back into the background. The recent immigration summit was a bit of a disaster with the presidents of Mexico, Honduras, El Salvador and Guatemala not attending. Exactly the countries needed to get on board with efforts to fix the problem. Nobody is paying attention right now because of the Jan 6 hearings.
They constantly try to escape from the darkness outside and within
Dreaming of systems so perfect that no one will need to be good T.S. Eliot
If you are deep enough into the right wing echo chamber there are two things that are abundantly clear. First is that the Biden family are an organized crime syndicate. While Hunter gets all the press because he is a fool, it is Joe that is pulling all the strings. Second is that the 2020 election was stolen. You really don’t need to be that deep in the echo chamber to be inundated with all kinds of information supporting those two theories. If you believe that then of course you need to impeach. Better yet if you can impeach both Biden and Harris and get Trump (the rightful President) back in the White House.
It is very interesting just how much these two beliefs mirror the left’s view of Trump and his family.
Re: 68% of Republicans think that Biden sould be impeached... [torrey]
torrey wrote:
If you are deep enough into the right wing echo chamber there are two things that are abundantly clear. First is that the Biden family are an organized crime syndicate. While Hunter gets all the press because he is a fool, it is Joe that is pulling all the strings. Second is that the 2020 election was stolen. You really don’t need to be that deep in the echo chamber to be inundated with all kinds of information supporting those two theories. If you believe that then of course you need to impeach. Better yet if you can impeach both Biden and Harris and get Trump (the rightful President) back in the White House. It is very interesting just how much these two beliefs mirror the left’s view of Trump and his family.
What do you think about the conflicting beliefs that seem to mirror each other? Can they both be true? No, so one of them is false. How can any person figure out which one is true?
torrey wrote:
While Hunter gets all the press because he is a fool, it is Joe that is pulling all the strings.Wait, "sleepy Joe Biden" is actually a stealth criminal mastermind ??
Now l have so many questions ...
DarkSpeedWorks: Jun 18, 22 6:37
Re: 68% of Republicans think that Biden sould be impeached... [DarkSpeedWorks]
DarkSpeedWorks wrote:
Now, l have so many questions ...
Hence the conflicting beliefs mirroring each other. Trump is a bumbling idiot, but somehow is able to orchestrate the things he has and stay out of jail?
Re: 68% of Republicans think that Biden sould be impeached... [CallMeMaybe]
Call me crazy but I trust myself and the evidence I’ve vetted., Trump family: crime syndicate (also really not that good at it). Biden family: typical run of the mill political class.
It's called projection.
And by that, I specifically mean that Trumpers are projecting all of his faults onto Biden.
BTW, don't construe this to mean that I love Biden or think he is without fault.
-----------------------------Baron Von Speedypants
-----------------------------RunTraining articles here:
http://forum.slowtwitch.com/...runtraining;#1612485
Same old same old. The "perfect call" went beyond politics and became the "impeachable call". So now the "mob boss" must go. Echo's heard only by the senders.
Exactly. The same people who claim his brain has gone to shit are also arguing he’s a criminal mastermind of the lizard people.
Re: 68% of Republicans think that Biden sould be impeached... [Francois]
Like a monkey at the zoo….
We impeached trump for quid pro quo with Ukraine right?
I believe this is Joe taking about doing exactly what trump was impeached for… if it is good for the goose it is good for the gander? I know, I know it was before he was president.
https://m.youtube.com/watch?v=QE7PwqmzSu0
“Ducks for cover before the poo gets thrown back”
Re: 68% of Republicans think that Biden sould be impeached... [Dougie2008]
From USAToday some time ago.
Based on our research, the claim that Joe Biden threatened to withhold $1 billion from Ukraine to save his son's job is FALSE. The then-vice president leveraged aid dollars to persuade the country to oust its top prosecutor as part of anti-corruption efforts endorsed by other international players that were unrelated to his son, Hunter Biden.
Dougie2008 wrote:
Like a monkey at the zoo…. We impeached trump for quid pro quo with Ukraine right?
Fortunately it is only the extreme fringe that believe such nonsense. Reasonable people can do a tiny bit of research and find that your spin of a selectively edit clip is nonsense.
https://www.factcheck.org/...n-biden-and-ukraine/
https://www.usatoday.com/...osecutor/5991434002/
https://www.nytimes.com/...ma-china-hunter.html
