2019 Quintana Roo PRFive triathlon bike (56cm) 3500 CAD
$3500 CAD. Will ship, coming from Vancouver, BC, Canada.
ready to race. This bike is fast and comfortable. Only ridden in nice weather or on the trainer. Selling because I am stepping back from triathlon.
Specifications
Frame: 2019 Quintana Roo PRFive 56cm in Jet Grey matte (Rim brake version). Full Carbon Fiber (30T). Frame has lots of integrated storage with the bento box and the draft box for a repair kit. Frame Stack 560mm / Reach 435mm. Adjustable seat tube angle (77-83 deg) The frame has some slight tire rub on the inside non-driveside chainstay but otherwise is in great shape.
Cockpit: Tririg Alpha X w/ Tririg Gamma 1 extensions (full carbon) with tilt kit and complete spacer kit. This cockpit is very fast and very adjustable. Having all the spacers means you can really dial in your fit. You can adjust the armrest position by 9.5cm! (610-705mm; currently set at 680)
Drivetrain: SRAM Force 22 mechanical/rim brake - 2x11 speed SRAM R2C shifters with 52/36 Rotor NoQ aero chainrings and 11-28 cassette. 170mm SRAM Force carbon crankset w/ Power2Max Type S power meter
Brakes: Front Tririg Omega X, Rear Shimano Ultegra direct mount
Wheels: HED Jet 6+ 60mm deep section rims. These have an aluminum braking surface for consistent and powerful braking with a carbon fairing to improve aerodynamics. Wheels are tubeless compatible and are currently tubeless with Continental GP5000TL 25mm tires. The wheels can be setup with tubes if thats your preference and I have a slightly used set of 25mm GP5000 clinchers I can throw in.
Other bits: Fizik Mystica saddle, Bottle cages as pictured (1 behind saddle, 1 on aerobars, 1 in frame), Look Keo pedals
Geometry: https://www.racycles.com/product/detail/15270
Photos:
https://drive.google.com/...xrz18494BI9Ktfk99w0c
