Thank you VERY much. What's BB?
So regarding the chainset/crankset are there any sizing variations where I could possibly choose the wring size for my bike?
Duncan74 wrote:
Park tools website used to be my go to for all bike stuff. Won't have tribar assembly, but you'd be following the instructions specific to the bars you choose.
As for order of assembly, to be fair as you can't ride until it's all there then I'd tend to do it in one hit, but within reason you can go in any order.
I guess Chainset which then defines what BB you need , and then what B B in stall tools would be next if you had to. front/rear mechs at any time. Shifters need to happen after bars that happen after the frame/fork you've got. Add cables and chain and you're most of the way there. Don't forget things that are (essential) nice to have, like bottle cages, garmin mounts (the mount you may want to select after you figure out the bars and see what space you have. k-edge do a good range but I've bikes that nothing fits on, Black Zipties and the plastic basic gamin 'puck' just seem to work.
My list of frustrating holdups from past builds though:
Bar tape
End caps for mechanical cables
The plastic guide for cables under the BB
Frame lugs for external cables near top of downtube
Tools / etc to make sure you have:
Carbon assembly paste for seat and aero bar extensions.
Copper slip for use on all bolts/threaded things - will last for years - seriously, I do all own maintence, built 3 complete bikes and was 15 years ago I bought the tub and I've still a third left.
BB tool.
Large car mechanics torque wrench for BB
Small parktools torque wrench for all the other bolts (yea, I know it's debatable, but for me I am a huge advocate).
Adapter between 1/4 inch and 1/2 inch drive for the bits to be able to fit both above....
Nice quality set of allen keys (ok, i had some cheap ones that lasted 15 years but treat myself to some silca ones last year and they are nicer to use.
Electrical tape - just darn handy during assembly when you need 3+ hands to hold tools and parts.
Wire cutters - can't really get away with the cutting bit on pliers.
Chain tool - you'll need one to be able to adjust the chain you buy down to the length you need even if you are going to be using quick links going forward.
Bike stand. Be careful where you clamp to, and for BB install wait until you've got the wheels on and can stand on the floor to use the big tools to get the 35-50Nm generally needed.
Final tip.
When you are cabling the gears, make sure you add the metal ferule on the end that goes into the shifter, and for mechanical rear shift then cable it all with the barrel adjust in middle and make sure the shifter is set as it in the outer position, then push the rear mech gently in to about the 3rd cog, tighten the cable and let it go. You should find that the mech takes up the slack and is pretty much perfectly indexed, at least within the range of adjusting the barrel. If you don't do this then I find you need another hand to pull the cable with pliers whilst tightening the cable bolt. Similar with the front mech, but set shifter to the inner cog, hold the mech out slightly to almost (not fully) in line with the outer ring and clamp. This is easier before the chain goes on, and from here it's easier to make small adjustments later.
