A few times I have read here that some triathletes feel that efficiency in the swim is not that important and that surprises me. So I ask, what do you think?
My opinion is that it is important. Both swimming and biking are all about trying to move as fast as possible through a fluid--that fluid being water or air. You can be Armstrong or LeMonde and you will still finish close to last if you ever try to ride in a race with a parachute (a real one) open behind you. Speed in both swim and TT bike events is a balance between watts generated and drag produced. Obviously, if you can produce unreal quantities of watts in the water, then you CAN get away with producing lots of drag, but you probably won't win (someone who can produce unreal quantities of watts in the water and produces minimal drag will). Also, being able to produce a lot of watts in the water can often mean a bigger upper body which usually means more weight to carry during the run.
In swimming as in all sports, simple training, practice, and fitness does make a difference. And there are no real 'aerobars' for the water (perhaps a wetsuit). But I think the real aerobar for the water is technique. I started out many, many years ago as a runner and biker and didn't swim too fast (often out of the water in the last 25% of the swim pack). Since then, I have swum a lot, but what I really did was pick the brain of almost every single able-brained person/coach who has watched me swim over the years. (I've also noticed that a lot of triathletes and swimmers don't like being told how they should change their stroke.) I put the advice I was given through the filter of my experience up to that point. I also watched a lot of videos of myself and of swim meets with world-class 800 and 1500 M swimmers. I learned a lot. To this day, I think about my stroke in EVERY SINGLE workout I do. Now I swim A LOT faster and many coaches now ask me if I swum in college. I did not.
Try it. It sure worked for me.
Where would you want to swim ?
