nanban_ronin wrote:
Yesterday I rode down some long downhills with this helmet between 40-45 mph (I'm trying to simulate the descent out of Snow Canyon in preparation for IM 70.3 St. George). I noticed my Jetstream helmet slightly lift from my head and thought it might even fly off (it didn't). I also noticed that some crosswinds batted the helmet around on my head.
Has anyone had similar experiences? Are these indicative of poor aerodynamics? I also noticed that I am not significantly faster on the same downhills vs. a road helmet.
This is something that has been noted with the MET Drone (
https://www.slowtwitch.com/..._Wide_Body_6005.html). The issue is that air wants to fill the low-pressure void under the tail and that creates lift which makes it feel like the wind is trying to pull the helmet off of your head. The effect is more noticeable at speed. The effect is minimized if there is good alignment between the tail and your shoulders / back as the void is more or less sealed when the gap is minimized.
The key thing to remember here is that if you get into that mode you are experiencing a significant aerodynamic compromise
The fact that the helmet is getting shifted by cross winds could suggest that yours is too big for your head or not compatible with your head shape. It's a pretty simple force equation where the cross wind pushing on the helmet profile is strong enough to overcome the friction interface between the helmet and your noggin.
If you can tighten down the helmet comfortably to minimize the shift in crosswinds you may also notice a reduction in lift at speed (as the helmet isn't being allowed to pull away from your shoulders). There's also a very real chance that this helmet just isn't right for you.
