refthimos wrote:
trail wrote:
Not tread thickness. My understanding is that's total tire thickness at the center of the tread. So rubber+casing. Only the casing bit is thinner. I was just going off the linked article which states "actual rubber tread thickness appears to be roughly the same," concluding that, "durability in terms of mileage should be unchanged."
Wait, so you actually read the entire article, rather than just skipping to the data tables like I did? /pink
If durability is indeed the same, or even just in the ballpark of the current 5000 TL, then yes it would seem that Continental made a number of improvements to the tire, with a few characteristics remaining essentially the same (and none worse), and so in that case the 5000 S TR would indeed be undeniably superior to the 5000 TL.
First world problems in my garage:
Well, the 5000 TL is more like a car tire in that it doesn't need sealant to actually hold air. Now how long that lasts on the road I wouldn't know.
Washed up footy player turned Triathlete.
