giorgitd wrote:
Unless you are racing up and down mountains, its difficult for me to imagine how carbon rim braking power is a problem, even in the wet. On a flatish course, my cheap Asian knockoff rims and blue pads are all the braking I need. I mean, it's a race, how much are you really braking? Earlier this year I was at what was predicted to be a dry race. Showed up to spitting rain and a saturated course. Did I wet my bibs because my race bike had carbon rims in these conditions? Nope, worked fine.
I find it strange that you accept mountain riding may be a problem and yet have difficulty imagining "how carbon rim braking power is a problem". First a few questions: How heavy are you? Do you only ride on pretty flat terrain? Do you think racing means not using brakes?
Incidentally, the moment someone says something like "it's a race, how much are you really braking?", their credibility is shot. The faster you want to go, and especially the faster you want to approach corners, or descend, the more important braking becomes. That's leaving emergency braking to one side, and that should never be left to one side!
What is the relevance of your anecdote about turning up to one wet race and not being scared? If anything, mentioning it makes it seem like this was a novelty for you, casting even more doubt over your credibility.
Let's just consider the relative requirements from brakes for different uses: Kinetic Energy = 1/2 MV^2
So the energy your brakes need to dissipate increases in proportion to your mass and in proportion to the square of your speed.
My mass is between 80kg and 85kg depending on the season, my current focus, etc.
I descend reasonably quick (and I descend reasonably fast whether I'm racing or not). I regularly hit 80km/h+
My Tri bike is a Felt IA which is not a lightweight at about 9.5kg IIRC and I'll add another 3kg as a conservative figure for water bottles, shoes, helmet, clothing, repair kit, bike computer, phone & keys.
So I could very easily find myself with a rolling mass in excess of 97.5kg and speed in excess of 80km/h.
KE = 0.5*97.5*22.2^2 = 24026 Joules
For comparison, a reasonably light guy (say 60kg), riding a road bike (say 7kg plus the same 3kg of extras) on the flat at a respectable 40km/h:
KE = 0.5*70*11.1^2 = 4312 Joules
The fact that the first example is on a descent can also add considerably more to the potential braking demand, but I'll ignore that now to keep things simple and very very conservative. So as you should now be able to understand, I regularly need my brakes to do at least 5.7 times more work to stop me compared to the lighter guy travelling at typical racing speed on flat roads. Even if we leave the mass of the rider and bike out of it, My same 97.5kg mass at 40km/h only requires 1/4 the work to stop compared to 80km/h (difference is square of the speed diff). Now, I've REALLY simplified things here. I'm not talking about braking power, just the total work they need to do for a given stop, ignoring aerodynamic, gravitational, and other influences. Braking distance depends on how quickly the brakes can do this work, i.e. brake power, and that's where the traction available from carbon rim brake tracks becomes a liability. The difference in brake power required will be considerably greater again than the difference in the brake work required. I would expect to need well in excess of 12 times the brake power to stop in a given distance compared to the 60kg & 40km/h example above. As others have mentioned, tyre traction is also a factor, but I've never skidded my front tyre (typically 25mm GP5000 on 19.5mm rims at 70-80psi) and I have pulled my brakes hard on a few occassions. Equally important, I've modulated my braking while decelerating hard, which is facilitated by not being at the very limit of the brake's traction.
Whether or not you rode a flattish race in the wet without concern has little bearing on whether anyone else should think your setup performs adequately.
