tttiltheend wrote:
Ai_1 wrote:
70psi might be a bit high for 28mm tyres (also depending on the rim), no?
On only moderately wide 19.5mm rims I use 25mm GP5000s at around 70-75psi front and I think 75-80psi rear. I might go low end of those ranges on poor roads and high end or slightly above IF I knew the roads would be very smooth. I'm typically well over 90kg including the bike.
It's not too high based on the Silca calculator, rough pavement, 28mm wide tire, and a male of average weight.
Of course such calculators only give a starting point and your actual tire width, weight, and personal preference will affect that number. And
I wouldn't recommend someone running tubes to push thing toward the low end on pressure as you're doing....
Well, from memory my 25mm GP5000 on 19.5mm rims measured about 28mm wide. This is the dimension used by Silca as the tyre dimension input for their calculator. The Silca pressure recommendation at my weight for a tri bike 50/50 distribution is:
For 28mm wide: 73psi
So if your're going by the Silca Calculator, my 70-75psi front 75/80psi rear range is perfectly in line, or conservatively high at that back if anything!
Incidentally I use less at the front versus rear for comfort on the extensions. Perhaps I should drop the rear pressure to match.
I've never had a pinch puncture or any other issue with this setup so I don't see a problem and certainly don't think I'm pushing anything as you suggest. In fact I'll probably start dropping the pressure a little lower when I get back riding outside regularly which I haven't been doing since last summer due to local Covid restrictions.
Hypothetically, if the OP was to use 28mm tyres as you suggest (I think 25mm is enough but 28mm isn't wrong) on his 21mm internal width rims, and if those tyres were GP5000; I think they'll measure about 30-31mm. If an average weight man is 75kg and their Tri bike weighs 9kg, then Silca says:
For 30mm wide: 64.5psi
For 31mm wide: 61psi
So if you're happy to rely on the Silca calculator (which is a better tool than most), then it appears you agree with me and 70psi is a bit on the high side for 28mm sized tyres. 70psi will work but Silca suggest lower and so would I.
