Slowman wrote:
there's a tool for breaking the bead, kind of like a tire jack but not. on the one hand i'd say that the need for a tool for this is enough for me to pass, just as if i need a tire jack to mount a tire i'll move onto another tire. but in this case, the system ought to work well enough that i'll almost never need to get that tire off until i'm going to replace it. i love the idea of a foam liner, because this theoretically allows you to ride in on a flat. okay, it's like driving with that space saver spare tire. but if it gets you into T2, that's enough. but i think there needs to be more education, videos, content on how to mount these things, with an acknowledgement that mounting is a bitch unless you know the technique.
My experience using airliners with Corsa Speeds is that, well, they work great on punctures were the tire still holds some air but not much. There they prevent you hitting the rim and you can ride pretty safely on low psi.
When the tire is not holding any air at all and you're using it as a run flat, it would probably get you in T2 (I've ridden on one with the tire holding no air for 30km one weekend and 60km the next before the airliner desintegrated, so total 90km - they advertise 50km) but riding on the airliner alone feels like riding on a flat tire, and at 200-ish W I was doing about 27-28 km/hr instead of 33-ish km/hr on my road bike. Would lose a lot of time riding that way, and it'd be problematic if it was the front which is gone.
If the sealant doesn't seal, and with Corsa Speeds that's a distinct possibility, you basically want to repair them at home because in the field taking the tire off would require their tool which is a bit bulky. With sealant as plan A and darts or plugs as plan B, airliners as plan C make sense.
