An hour of reading conflicting posts, I'm hoping to get a definite yes or no here. I have a 2014/15 cannondale supersix evo (SRAM). BB30 printed on the frame but definitely pf30 setup.
Only one side needs replacing. There looks to be small cups the bearings go into, with no inner sleeve - at least doesn't look like it. When I look through, I can see around 2 or so mm of the bearing edge and wondering if these can be knocked out (using the correct tool), or will the cup have to come out also? And if so, would the cup need replacing or can I simply put the new 6806RS bearing inside the old cup and press back into the frame (i have the tool for this).
I'm just super concerned the cups are fixed and could damage my frame trying to remove them
Thanks,
Thanks,
