Jloewe wrote:
Getting my yearly tune up for the TT bike this weekend. Unfortunately it looks like my left Ultegra pedal has just had it after what has to be something like 13 years. Now I have just the spd-sl pedals on my road bike and honestly don't see a damn thing wrong with them. Can someone give me a legit reason I should spend $160 on a pair of Ultegra when I can just buy another of those spd-sl pedals for $60 on Amazon?
there are some features to the higher end pedals that may or may not be relevant to you.
Cornering clearance is greatest for Dura Ace, slightly less for ultegra, slightly less again for 105 and the base models.
longer spindles available for DA and Ultegra
slightly higher spring tension (unless that's been changed since the last time I looked)
better bearings. (does Dura Ace still use needle bearings in the pedal?). I think that definitely helps the longevity, my original DA pedals still work fine, although I do mostly use my later model Ultegras since they have the wider metal platform instead of the original plastic one.
edit: you probably won't feel any difference between them, as they're still the same basic pedal and even the base models are really good.
Swimming Workout of the Day: Favourite Swim Sets: 2020 National Masters Champion - M50-54 - 50m Butterfly
