ericmulk wrote:
playguy wrote:
ericmulk wrote:
playguy wrote:
ericmulk wrote:
playguy wrote:
I have the Kiwami sleeved swimskin and absolutely love it, and have had very fast and comfortable swims in it. While some roll down the tri suit underneath, I have never done that as it seems a real pain to get it back up and on without wrinkles while wet. My Kiwami sleeved suit is quite comfy to swim fully up under the swimskin. Their suit also comes off quite easily while on the run in T1. HIGHLY recommended!
Have you timed yourself in the pool with and without it??? Does it seem to make you more buoyant like the wettie???
Nope, have not done tests, but DD has. I don't need to as repeat use in chlorine will negatively affect the coating. My AG race results for the swim portion substantiates the swimskin being faster so I don't need pool tests.
So how much faster per 100 yd???
https://accelerate3.com/...rush-my-impressions/ Thanks PG. Looks like at least 5 sec/100 m which is quite significant.
I tried the Kiwami sleeved swim skin, and pool tested it. I have big for my size, shoulders, chest and biceps (years of competitive wrestling)? The suit fit well below the chest, but felt like a straight jacket above that.
In my pool test I was 10 seconds slower per 100 with the swim skin, as compared to a standard speedo
(1:30 vs 1:20). This test was 5 x 100 x 4, alternating swim skin and no swim skin. These results were significantly influenced by the poor fit (for me). I do think the Kiwami suit was extremely well made, but only comes sleeved, and just does not have a size that will work for me.
How much time it will save you depends entirely on your swim position. If you swim fast, high on the water, I would expect 2-3 seconds per 100, at most. If you are a deep in the water tug boat, I think 7-10 seconds is possible. These suits are not legal if they have ANY buoyancy, so are all about drag reduction!
I bought a sleeveless Roka swim skin, and wore it with my sleeved Kiwami Trisuit underneath last year in Campeche. At 65 years old I had the 3rd fastest swim for 50+, and fastest by 6 minutes in my AG. That is obviously not a test, but I am confident it did not make me slower :-)
In regard to sleeved vs no sleeves, I think it depends entirely on a persons build. Personally, I doubt the sleeves will make you any faster.
In regard to top down or up- in my experience I found it very difficult to get the wet top pulled on, and for anyone who watched Miami you would have seen the world’s best, and most prepared triathlete, loose at least 15 minutes in transition in the wrestling match with pulling up his top. Top up, but mostly unzipped, is the way to go! Any of the current tops are make with high stretch, compressive sleeves, and they will not take in any water! (If they do, they would also create drag on the bike, so get a new suit!)
