SRAM Force eTap AXS Groupset-2x12 Hydraulic Disc Brake/Shift Levers
Kit was removed from a new bike build and swapped for a SRAM RED AXS upgrade.
Kit has never been ridden and a chain was never installed through either derailleur
Calipers will need re-bleeding
This SRAM Force eTap AXS Road HRD Group includes:
- Right FORCE eTap AXS Hydraulic ETAP shift/brake lever (1780mm cable length)
- Left FORCE eTap AXS Hydraulic ETAP shift/brake lever (915mm cable length)
- Front and rear FORCE AXS disc caliper and pads (160mm flat mount front adapter NOT INCLUDED but available retail for $20.00)
- Rear FORCE AXS disc caliper and pads (160mm flat mount rear adapter is INCLUDED)
- Front FORCE eTap AXS Derailleur and battery (derailleur mounting bolt, washer and shim kit NOT INCLUDED but available retail for $35.00)
- Rear FORCE eTap AXS Derailleur and battery
- Charger and cord
- (2) Sram hydraulic brake line barbs, (2) olives and Sram Barb installation tool
- Sram Bleed block
- (bottom bracket, disc rotors, crankset, cassette, and chain are NOT INCLUDED)
