I'm going to have to disagree, only a bit, with some of the advice you've been given. Here are a few thoughts to consider while digesting the previous advice:
1. While we speak in terms of 5 second, 1 min, 20 min, etc. power. Those are really constructs we use to define measures of fitness/form but our physiology is more complex than that. You can raise your FTP with Tabata intervals or with just increasing mileage substantially. Even though there are methods that are more efficient use of time, you will not be tanking your FTP by adding in intense efforts which are likely to improve your power at 1 min/5 min, etc. Different riders react to training stimulus differently and you really need to find a plan that fits your needs.
2. Having a higher FTP is great for TT's, Tri's or pretty much any cycling event. However, resilience to intense repeated efforts is important too. I've had different times in my training where although I had a very similar FTP, my resilience to repeated efforts above threshold were much different. It's common to think in terms of matches you have to burn before your matchbook is empty. Having more 'matches' in general is much more important in a criterium or cx race than any triathlon event (drafting or non-drafting). However, that same resilience can be helpful in turning a good TT split on a course with rolling hills, especially if draft legal. That being said, your FTP being higher is still most important, especially given the type of races you are describing.
Good luck with your training!
Scott
I have deceptive speed.........I'm slower than I look!
Scott
