Hi,
I have the Missile Pro Evo aerobar with J-bend extensiosn (link) on my bike.
Issue 1: It always bothered me that there wasn't more of an upwards bend at the end of the bars to grip onto (with a straight wrist).
Issue 2: After switching to Di2, the extensions now also suddenly seem a tad too short. The previous mechanical shift levers added quite a bit of length compared to the Di2 shifters. The extns are already mounted on the max length position.
So I'd like to solve both of these problems at once.
Pro does sell a set of ski-bend extensions for that bar, but whilst those would solve issue1, i have no indication that they would be any longer (issue 2).
I can't easily use any other aftermarket extensions, because that bar has a proprietary extensions shape (oval) with proprietary mounting interface.
So here's my question:
Is there any way to extend the bar on the front with a 2-5cm extender (that potentially also bends up a bit). Obviously that would have to be fixed to the original extensions somehow as well as accept the Di2 Shifters on the other end...
or should i just get a new bar and extensions altogether? ($$$)
if you can read this
YOU'RE DRAFTING!
YOU'RE DRAFTING!
