Cervelo P series Di2 front derailleur setup issues- HELP!
I just bought a P series and my winter project is to build it up. I am using the wheels manufacturing BB Right OUT 29 bottom bracket. I verified I have the shallow cup on the non-drive side per the instructions. I am using the Sram Dub crank that accepts a Quarq spider and Shimano Dura-ace chainrings. For some reason, the front derailleur just won't go close enough to the frame. Thus, the chain is hitting the inner cage badly. I can't adjust it with the limit screws.
The bike is set up with synchronized shift.
I cannot find any adjustments on the e-tube software that would help me.
I have some spacers that came with the bottom bracket and I have tried a few combinations, but it just doesn't seem to help.
Any ideas?
Re: Cervelo P series Di2 front derailleur setup issues- HELP! [jharris] [ In reply to ]
Just off the top of my head, it sounds like the chainrings aren't in the correct spot.
Re: Cervelo P series Di2 front derailleur setup issues- HELP! [jimatbeyond] [ In reply to ]
Found out the damn chain catcher was holding up the back of the derailleur cage. I removed the chain catcher and now I will take a look again. Still no dice.
With BBright the WMF bottom bracket has usually wrong chain line. The whole crankset is moved to left with aprx 1-2mm. I had the same issue with GXP/shimano cranksets. The solution was a Hambini or BBinfinite one piece BB. It is a little difficult to measure, but you could check the symmetry of your crank arms next to the down tube.
