s5100e wrote:
jaretj wrote:
RChung wrote:
s5100e wrote:
that is pretty cool stuff. It would be interesting if the companies who made the power meters used a calibration tool that was traceable... so we know that when it left the factory it has a traceability certificate, it was compared to the standard and had certain characteristics.Just to be clear, suppose Stages had a NIST traceable calibration for their left-side only PMs prior to leaving the factory. Would you accept that?
They clearly state if their products are 1 or 2 sided so I would. That doesn't mean it's the best product, but if they certify what they have is within the tolerances they publish, then they are doing what they say. With that said I still know it's not the best product for my application.
I could use a turbine or a coriolis meter to measure fluid flow, (volume or massflow). Both could have calibration certification but one is clearly better than the other.
I as well would accept that, as long as we know constraints of the system then so be it as jaetj said and I agree.
and while we are at it I can jump down a second rabbit hole: so assume we know when it left the factory it was calibrated and traceable. So any time thereafter it may no longer be so. To deal with that you could have a way to send it back to the company (or somewhere) and have it re-certified, as often as you see fit. I doubt that there will ever be a working (user) solution to this dilemma but for certain situations, at least if a standard existed then we have a place to start. Right now nada!
