triguy86 wrote:
stevej wrote:
triguy86 wrote:
In the market for a new road bike and I’m attracted to the Enve Foundation and Zipp 303S wheelsets because of their price point. But they’re both tubeless only. I have zero tubeless experience so I’m wondering if I’d regret getting them. I’ve had 2 flat tires in the last 5-6 years probably on tubed wheels.Neither wheel is "Tubeless only" as a setup. You can still run a latex or butyl tube in the wheels. The mandate is that you have to run the specific tubeless ready tires (TLR) that are compatible with those wheels.
I think the list of tires currently "approved" for the both those wheels is relatively small. But within the next 1-2 years, you will see that list grow even larger.
Just to clarify, Zipp 303s should be used with tubes in “emergency situations only”. Per the Zipp site. I’d call that tubeless only personally. Enve says you can use tubes for regular use.
Where did you see that on zipps website?
Quote:
Zipp encourages consumers to confirm compatibility with the tire manufacturer before installing other tubeless or tubeless-ready tires on Zipp’s new 303 S and 303 Firecrest disc-brake wheelsets. Tubeless tires may be used with inner tubes.From: https://support.sram.com/...t-disc-brake-wheels-
blog
