Duncan74 wrote:
Ok.answer A. There is no compatibility issue that means a new cable would require the drivetrain to be replaced. So recable.
But. My bet is answer B. You didn't say which shift cable has broken, nor if the drivetrain is 8/9/10 speed. By should of things, your description, this has been well used, and so there is a good chance the chain, chainrings and cassette need to be replaced. As for the mechs, the rear jockey wheels could be toast and for the front, for all I know the cause of the cable break was that the mech has seized or partially seized. So in some situations then if there was that much that needed replacing doing it as a full set would make sense.
Either way the communication between the mechanic and yourself have been better
But to be absolutely clear to the OP.
Just because the chain / rings / jockey wheels / mechs are really worn, that no reason to not just change the cable.
And the 8/9/10/11/12 speed is irrelevant.
If it was the mech that was half seized, same thing the rings and chain and cassette do not need to be changed.
What you can do to check is simply disconnect the cable at the derailleur. 1 Allen key needed only on 1 screw !
Then with the bike upside down turn the pedals. The derailleur should be in the smallest cog. Just push the derailleur body across whilst pedalling and check it moves across OK. (Just watch where you put your fingers so you don't jam them in the rotating wheel or cassette. - ouch !).
2nd, then try the shifter (/ pulling the cable back out) whilst it's disconnected to the derailleur. It should be smooth and easy. If its chewy and sticky or rough... there's your problem.
A pound to a pinch of shit, the cable will have just got sticky and maybe have a broken frayed strand or two inside the housing (the 'outer' cable) or near the shifter. A Ā£2 part. I'd maybe change the outer at the same time. Ā£5 for inner + outer to do both front and rear at at Wiggle.
https://www.wiggle.co.uk/...amp;utm_content=mckv|sl4f0CCF3_dm|mcrid|295292317327|mkw||mmt||mrd|5360621409uk|mslid||&mkwid=sl4f0CCF3_dm&pcrid=295292317327&prd=5360621409uk&pgrid=58852352866&ptaid=aud-967287486445:pla-523199302738&gclid=CjwKCAiAxeX_BRASEiwAc1QdkUk-58gbQdBzo_yYthZVqmLT649lpyc5WQM5WXir7X6zaJZQ9mj00RoCofYQAvD_BwE#reviewsSection
The chain + rings + cassette on my 3rd worst old mtb (20+ year old bike) are worn to buggery. Still works fine for a bike for when I'm camping or commuting. The chain is at about 2% stretch. Any bike shop would want to get me to spend Ā£200-300 to renew the drive. I'd not use it in that condition for an ironman. But as a beater bike ? It's fine.
